2006 Pacifica passenger side headlight replacement help
Old 02-07-2008 | 08:18 AM
juanchm17's Avatar
Default 2006 Pacifica passenger side headlight replacement help
Can anyone help with how to replace the passenger side headlight bulb on 2006 pacifica. Do I need to remove the air filter assy.
Old 02-07-2008 | 12:30 PM
mplue's Avatar
Default RE: 2006 Pacifica passenger side headlight replacement help
If it's like my '04, there are two screws on top that hold it in place. Remove those and start pulling toward the front of the car. There is a plastic clip that is on the bottom and will may take some force to release it. Just pull and it will eventually come out. Once you have the headlight assembly out, mine had two rubber covers that went over the hi and low beam bulbs. Remove the cover and you should see two small torx screws. Just loosen those and rotate the bulb holder, it should only turn one way. That should get the bulb out to where you can replace it. Put it back together and make sure you get the plastic clip on the bottom of the assembly. You'll know if you don't as it will have too much play. Hope that helped. I've changed my headlight bulbs twice now.
Pappy118
12-04-2011 12:50 PM
Stingray
07-24-2011 08:51 PM
madmac
12-10-2008 01:51 PM
onedownfiveup
01-17-2006 05:20 PM
cajundaddy
11-20-2005 09:50 PM
