2006 Pacifica performance tips
Old 08-20-2012 | 03:00 PM
turbobass's Avatar
Default 2006 Pacifica performance tips
so i bought a 06 PAC AWD 3.5 with 275K Km on it ... got a really good deal . Had performance issue ( sticky short runner valve flappers ) .
1st , gave it some sound and cheked the Cat to see if it is clogged up ... cat is just fine and flow is great . changed muffler for magnaflow 2.5 inch a the rear tip ... gave it some punch and hardly no sound . so i decided to replace the other muffler ( the one in the middle of the car ) with a magnaflow ... and wow , great deep sound and not loud at all ( i have 5 kids and use this car for trips and dont want a noisy exhaust ) and gave it some more torque . i can say by replacing the 2 pieces of exhaust , it gave me a quite noticable performance gain and economy. in canada we use l/100 so i went from HWY 15.7L/100 down to 11.7L/100 km - cruising speed of 120km/h.
tomorow i will do the injection cleaner and in a near future , i will remove the short runner valve system as i think the rubber on the flappers that close in the intake part are so soft that there is a lot of turbulence in the intake manifold and unequal air flow to the cylinders. WILL KEEP YOU POSTED !
Cheers
Old 08-20-2012 | 09:11 PM
ntwrkguy1's Avatar
Cheers
Question for you -- did the Magnaflow mufflers bolt in? Or do you need to cut and weld them in?
That's a pretty impressive gain you picked up on the fuel economy, and any extra torque is always a good thing.
Old 11-19-2012 | 07:10 PM
GMON's Avatar
THANKS Iam adding dule exhaust to my 06 3.5 diden't think about center muffler however i will change both now, should I add center muffler to new pipe as well?
Old 11-19-2012 | 10:29 PM
cirrus98's Avatar
Hey turbobass, can you give me the item codes and where you bought them from? could you also try an include some audio to hear whats it like. I like to idle "roar" of my 3.5, but if you added MAGNAFLOW, man I would love to hear this before I decide to go threw with changing mine.
Old 11-20-2012 | 07:17 AM
turbobass's Avatar
Ok ill try to post vid of idle and wot this week.
Old 11-20-2012 | 08:38 AM
Grenadiers's Avatar
Part numbers and/or where you purchased the 2 parts from would also help (i.e. Canadian Tire, Napa, etc)...
Cheers!
Old 11-29-2012 | 11:50 PM
cirrus98's Avatar
Hey turbobass, did you forget us???
dre2kx
09-07-2013 07:15 PM
a_kraker99
06-10-2011 02:55 PM
denumbr
12-10-2007 07:17 PM
New07Sebring
11-26-2006 08:36 PM
02-26-2006 02:32 PM
