2008 Pacifica Intermittent Hard To Start
At my wits end. Have had an intermittent hard to start prob w/my ‘08 Pacifica LTD 4.0L since 20k mi (now have 133k mi). 5 diff Chrysler dealers & 2 independent mechanics have been unable to fix it over the yrs & have charged me thousands of $ claiming they can fix it. I’ve now replaced the battery 7 times, battery cables, ignition switch, new spark plugs, multiple load tests, checked ground wire issue, all to no avail. There is no rhyme or reason as to when/why it happens. It always starts eventually..just doesn’t turn over right away. I’m hoping someone in the forum can ID cause.
Is that a design flaw? How much did that cost to fix? Seems crazy you can have a pervasive prob like this, never get any trouble codes & all the certified Chrysler mechanics that have looked at my car over the years not check for the issue you’ve described.
Almost all dealer techs are paid by FLAT RATE TIME ...wire repair does not pay well and for an intermittent problem at that. YES I know very well how frustrating it is for the vehicle owner....I've been there, done that on BOTH sides of the coin!
Good luck to you, and I hope the posted suggestion will take care of the problem you face.
If you are referring to me...That I could not say as I've been out of the trade for some time and was never involved with warranty handling. I would GUESS that if they found the starter solenoid (where the small wire hooks up) to be bad, then that MAY be covered and associated wire end repair...BUT I can't tell you that with certainty.
Mohamed Ahmed
17
08-24-2019 10:40 AM
Mikey0659
02-12-2018 04:17 PM
