anyone come across this one. cooling fans
2006 pacifica, 3.5l. Cooling fans come on about 15 seconds after turning car on, even if
it has been sitting all night. They do cycle off, but its like it has already reached high
enough temp. for the fans to come on, when it hasn't been running. No codes. Is
there a sensor that could cause this, or is this normal for this car.
RE: anyone come across this one. cooling fans
Well, I was just wondering if anyone elses pacifica did this. Sarg, you have confirmed it. Don't you think it is strange it does that. Any other car I have ever driven, the fans don't come on until the temp gauge goes just above the midpoint of the gauge. Sarg, does yours come on after sitting overnight.
If the AC compressor is on at start up, I believe the fans will kick on regardless, even at startup. Has anyone noticed the postion of the AC switch at startup? Defroster,AC, AC Max, will all kick on the compressor and the fans. Out of curiosity, make sure the AC selector is "off" before start up and see if the fans kicks on. Just a thought.
United1, I can't believe it, you were right. I started the car up 6 different times, 3 with ac on, 3 with it off. when ac was onfans came on about 10 seconds after compressor kicked in. with it off, they would not come on, and I let it sit there and run, and then hit ac on, and they again came on about 10 seconds after compressor kicked in. Thanks man, I won't worry about it anymore. Sarg, you should check yours. My wife always kept the ac button on, and thats why they kept coming on. Thanks again united1, good call.
You are welcome, glad I could ease your mind. Mind if I print this:
I don't hear that too often around the house from the misses, maybe I'll show this to her.
