Anyone know where to find these bushings?
Old 01-13-2013 | 09:03 PM
dcnaz's Avatar
Default Anyone know where to find these bushings?
I can't seem to find these bushings: 2004 pacifica AWD, lower control arm REAR bushing. Both sides are worn out. Front bushing on the control arm are cheap and easy to find. The rear ones I cannot locate any freaking where. Any ideas? Also, any ideas on whether this is a big job? I worked on cars many times. Just never changed these bushings before.
Old 01-14-2013 | 08:43 AM
busboy4's Avatar
Not sure how much you want to spend, but Rock Auto has the control arms for $90-$100 which gives you new front and rear bushings and new ball joint in one R&R action. In that you will have to remove the arm to change a rear bushing - after you find one - and that they are press fit to my knowledge, I think you will be much more satisfied with a full control arm R & R.
Just my two cents.
Old 01-14-2013 | 11:59 AM
dcnaz's Avatar
if both bushings come with the arm that is good. how is it pressed on? what kind of special tools needed?
Old 01-14-2013 | 02:13 PM
busboy4's Avatar
Oh, that's the point. If you buy the arm the bushings and ball joint are in place. Just R&R the whole control arm. Make sense?
Old 01-15-2013 | 10:32 AM
dcnaz's Avatar
Ohhhh, I never knew that about replacing a bushing vs. the whole arm. I thought these bushings would still need to be fit pressed on the otherside. I know they come fit-pressed ready to go when I buy the arm, but didn't that it is kind of easy for these bushings to slide on the place they are supposed to go.Thanks!
jimmy154
11-03-2011 08:13 AM
ttype
10-30-2011 12:28 AM
ajhoward
09-23-2011 01:25 PM
shootme5150
08-30-2010 05:50 AM
