Battery warning light
Hi Guys,
New member I was was wanting to know that when the battery light comes on and off intermittently could it be the voltage regulator or the alternator. If so how can you tell the difference.
Keep it simple, A loose/worn alternator belt could cause intermittent battery light. Also check and clean all battery B+ and Ground connections.
PCM's rarely fail and Alternators are pretty robust on these cars. Trouble shoot and repair as needed. Don't just throw parts at it.
