body side molding
Hi,
if you are talking about the mid-door plastic strips that take the "door dings", they are held on with double sided adhesive tape. If you need to remove them, you can heat them to around 80 and gently pry and pull them free. The door surface will need some cleaning and prep before re-install and if you are re-using the piece you will need to re-apply some adhesive.
Desirae Lyn
10-04-2015 01:04 PM
bpress54
05-04-2014 09:13 PM
