Brake pedal violently vibrates
Hello,
The brake pedal of my 2006 Pacifica violetly vibrates when braking. There has been new tires installed, rotors and brakes changed. Brake light came on just two times for a few second and then went away. It has 90K miles FWD.Please help !!!!
Vibration
Have you tried to retorque the lugs to the proper torque? I have seen people who don't know how to install tires correctly and just tighten the lugs till their impact gun stops turning.
I would try and jack it up loosen all the lugs and torque them in a cross pattern starting at 30' lbs. and then 60' lbs and final 95ft. lbs.
ABS brake shudder
Also have issues with violent shudder of ABS brake system. Only happens going down hill at high speeds, freeway speeds. Just a tap on the brake causes the ABS braking to kick in and the whole car to shudder. Is their a sensor that detects the angle the car is driving? if you are on the flats driving freeway speeds it doesn't happen.
Is ABS light is on?
monsterdub
05-05-2024 12:10 PM
key5000
22
10-14-2017 12:52 PM
procraneop
08-07-2014 08:55 PM
