Can't get ABS sensor off of the rear -- ABS light --
I can't get the rear ABS sensors off.
I can't find the procedure in the service manual either.
Chrysler Tech, with a lot of typos, seemed to write that you have to loosen the hub, which it does seem like you have to do.
But I don't know how to loosen the hub, once I get the hub bolts off.
Do I have to loosen something else or was it rusted/oxidized together?
What kind of scan tool do you need to tell you why the ABS light it on?
OK, so I found out through the use of my Fluke 77 multimeter, a good one will read between 5M ohms, to 7.5M ohms. and they will read only one way, swap the leads and it reads open. Now I also found that some read with the negative lead on the negative post, and the positive lead on the positive post, and some read the other way around, with the negative on the positive post, and the positive lead on the negative post. Either way it reads, if you reverse the leads on that particular sensor, it should read open.
I also found that it was impossible for me to get the sensor out of the rear hub without cutting a notch in the rock guard from the hole that the sensor wires go through, out to the edge. (Seeing that this notch is on the bottom of the rock guard, if a pebble does get in there, the slot is on the bottom and hopefully it falls out by gravity.)
After I replaced the bad sensor, it took about a mile of driving before the ABS computer reset the ABS light.
Gasman
01-15-2011 09:07 AM
