car won't start after hitting a snow bank!
Hi folks!
My wife informed me today that she slid into a snow bank. I don't know all of the specifics but I do know that the airbags did not deploy and it appears as though the car will now not start; any ideas? Thank you in advance.
More info......Does it crank, ??? Where is the car, ??? Is it still in the snow bank, or did she drive it home and the next morning it doesnt start???
Just a speculation, But as it stands now, It could be just coincidence, to an oil pan that got sheared off of the car, to a computer that got crushed, and EVERYTHING in between.....
DETAILS.......DETAILS.........DETAILS
I had a similar problem but it was with an lhs.
Resetting a computer......I doubt it, but if you wish to try.....Remove both battery cables, touch them together, count to ten, and reinstall....
My apologies.....
I-H-S stands for interior High speed Buss communication system used on Late model chryslers....Of which I dont think PACs had them, At least not prior to 08
The confusion set in because an Interior buss would likely not be damaged by an exterior collision, and it would not stop the car from running
Once again My apologies for the confusion.
I had an '89 and a '96 Ford that had inertial switches (accessible in the trunk/cargo area) that shut off the fuel pump in the event of rapid deceleration. Do later model vehicles - specifically Pac's still have such an animal? Or is the function handled through another system now?
Unfortunately, it isnt handled at all.....Ford and a few select EURO -Cars, still use this animal...But Pacs never did, Nothing Mopar ever did.
It wasnt necessarily Rapid decel that did it.....Back in the day, I had more than my share of Back doors that were slammed too hard, or speedbumps that were aproacched too fast.
I was recently at an accident scene where a car was flipped upside down, and was still running. No GAs leak.....
The fuel pumps on Mopars, are designed to stay energized, until Crank signal is lost, If the car doesnt stall, The pump continues to run...If it had lost significant fuel pressure from a leak, it would stall, and the pump would be killed by "LAck of Crank Signal".
