Dodge Stealth 1994 daytime running lights
Hi,
if you motor in Canada your head lights have to be on like 60 % of high beam.
I see in The USA some states will also implement this idea.
Lights wont shut off or don't come on any more?
Did quite a bid of research on this and if the original mosfet is burned out, there is a problem sub-ing it.
So, i ended up building a heat-sink assembly with two mosfets and the interlock wiring to the original module.
If you need any help let me know
Regards
Armin
Regards
Armin
