Headlight adjustment
Old 05-20-2011 | 11:42 PM
mtdewmn's Avatar
Default Headlight adjustment
Hello, I would like to know if there is any way to adjust the aim of my headlights on my 2007 Chrysler Pacifica. Thanks in advance.
Old 05-24-2011 | 07:50 PM
mtdewmn's Avatar
Bummer, I think I posted in the invisible section...
Old 05-25-2011 | 09:13 AM
Virglijus's Avatar
ALIGNMENT SCREEN PREPARATION
(1) Position vehicle on a level surface perpendicular to a flat wall 7.62 meters (25 ft.) away from front of headlamp lens.
(2) If necessary, tape a line on the floor 7.62 meters (25 ft.) away from and parallel to the wall.
(3) Rock vehicle side-to-side three times and allow suspension to stabilize.
(4) Jounce front suspension three times by pushing downward on front bumper and releasing.
(5) Measure the distance from the center of headlamp lens to the floor. Transfer measurement to the alignment screen (with tape). Use this line for up/down adjustment reference.
HEADLAMP UNIT ADJUSTMENT
The low beam headlamp will project on the screen upper edge of the beam (cut-off) at the horizontal lamp centerline ± 50 mm (2 in.). Horizontal aim is preset and can not be adjusted. The high beam pattern should be correct when the low beams are aligned properly. To adjust headlamp vertical alignment, rotate adjustment screw to achieve the specified low beam cut-off location.
Its a pity I can not add picture of the screen, becouse it is 49 kB size.
Old 05-26-2011 | 10:44 AM
mtdewmn's Avatar
Thank you Virglijus, I thought that little white screw was the adjuster, but when I turn it nothing happens, so there must e an issue with it. Thank you for the information.
Rustydog
06-22-2011 04:11 AM
CmdrData
04-02-2011 12:43 PM
chryslerguy2006
08-11-2007 03:55 PM
69roadrunner
06-26-2007 02:45 PM
GO TOPLESS
09-21-2006 11:49 AM
