High Idle Speed issue (Pacifica 2005 3.5L)
With it running,spray around some acetylene gas from a cutting torch. Alternately propane works, but be careful with it so that it does not flash. When the gas is sucked in, things should slow down, identifying the leak. Just a wild thought from the 70's....
Alex, I have the same issue, 2004 pacifica, I removed the upper intake to check where the spark plugs are located, put it back like it was before and now, engine revs up 2 times then turns off, Did you ever figure out the issue ?
#16
Alex, I solved the issue, get Auto-zone part number below and put it on the EGR tube top side. Reeving stopped and car runs great again.
FEL-PRO EGR Valve Gasket 72928, $2.69
https://www.autozone.com/emission-co...87486_0?review
#17
Removal
#19
#20
i did manage to find the original gasket. hopefully the one orileys sold us is just stuck forever somewhere and not in the pistons. after finding the original it works fine, the one we put on was clearly smaller and didnt fit right so that is why we lost it. got sucked in when we started it apparently.
