INTERIOR LIGHTS PROBLEM
I have a '05 Pac and now the interior lights won't turn on when they are pressed but they still work when I open the doors or use the manuel switch on the steering wheel. My husband checked my fuses and they were all working. Does anybody know what this problem is?
RE: INTERIOR LIGHTS PROBLEM
cost no I dont know what BCM u have installed and possibly u wont be able to install the BCM and have it work correctly It has been awhile sence I have install a BCM on a PAC. The installing is not the issue its once installed and proraming it if required would be the issue.
try un hooking the battery for a few minutes or removing the IOD fuse for a few to kind of "reset" or "reboot" the module (s) and see if it works again. Might be a temporary or longer term fix. ON mine, the power locks would not work by remote, or hitting switches on the door. After pulling the IOD fude for a few minutes and putting it back in, the locks work fine now. this had been for 2 months now. The IOD fuse in in the use box and labeled so. Maybe fuse 24?
PrivateLine
07-31-2014 12:54 AM
johnkaracalidis
10-11-2009 02:18 PM
Johnbush1
02-22-2008 05:00 AM
