Lightning bolt in between lines
Electronic Throttle Body
If replacing with a rebuilt unit, you may need to "Re-Learn" the PCM to the rebuilt Throttle Body at the dealer for accurate air to fuel ratios. This "Re-Learn" will run about $170. The Electronic Throttle Body price point starts at about $190 and goes up from there depending on rebuilt or OEM. Also check warranty on rebuilt unit vs buying OEM. More expensive unit will have lifetime warranty.
96LHSinfinityspeaker
09-12-2015 01:53 PM
