Low Beam Headlight Won't Turn Off 2006 Pacifica
Old 01-05-2017 | 07:44 AM
ByMinotti's Avatar
Default Low Beam Headlight Won't Turn Off 2006 Pacifica
I have a 2006 Pacifica with an aftermarket HID Kit installed. Those lights have been working fine since I installed them over a year ago. This week I am having an issue where the Low Beam HID lights won't turn off. If I turn the headlights off or turn the car off they stay on. The only way I can get them to turn off is by removing the fuse in the wiring harness that came with the HID Kit. Is there a relay on the 2006 Pacifica that would be causing this? I checked the fuse box under the hood and I didn't see anything that was labeled for the headlights. Any help would be greatly appreciated. Thanks
Old 08-13-2018 | 10:53 PM
Steven Pangilinan's Avatar
Default Bump...
Having the same issue...
Old 08-14-2018 | 06:26 AM
Taronga76's Avatar
If you put back in standard Halogen bulbs, do you have the same issue?
Are the sidelights (parking lights, I think they are called in the US, sorry) staying on as well?
Do the rear lights stay on as well?
I would assume that something has become damaged due to the lower electrical pull of the HIDs compared to a standard Halogen bulb, did you use CANBUS friendly HIDs at all?
Old 08-15-2018 | 10:40 PM
I almost did that, but because it's been raining daily and so humid, I didn't want to open up the headlamps and let some of that humid air in.
I did, however, unplug the HIDs for a day, and then plugged them back in... the issue seemed to resolve itself. If it happens again, I think I'll try a hard reset on the TIPM. Saw a youtube video on it, basically remove both battery terminals, cross them and wire-tie them together to discharge any caps in the system for a few hours. I'll just post back in this thread once I figure out WTF is going on.
Old 09-01-2018 | 10:21 PM
Disconnected the HID lights (harness only connects to the left headlight harness) for a day and plugged back in. Problem solved.
ByMinotti
10-31-2021 01:17 PM
Joshua Fisher
08-09-2019 10:45 PM
martywj
06-21-2010 11:33 AM
pdot617
04-22-2009 10:35 PM
sboyajian
01-19-2009 05:57 PM
