Moving Seats From 07 to 08
Old 02-24-2013 | 11:20 PM
BeachBoy's Avatar
Default Moving Pac Seats From 07 to 08
I am thinking about purchasing a 08 Pac with cloth seats. I have a 07 Pac with leather seats. The controls are the same on both. Can this be done? If so, how hard?
Old 02-25-2013 | 01:24 PM
ChryslerCares's Avatar
the muffler heat shield and vapor canister need to be removed to swap front seats:
1. Disconnect and isolate the battery negative cable.
2. Raise and support vehicle.
3. For right side front seat, remove muffler to body heat shield.
4. For left side front seat, remove vapor canister.
5. Remove four nuts attaching seat to floor pan.
6. Lower vehicle to access the seat.
7. Remove headrest from seat.
8. Raise seat to access wire connector under seat and disconnect wire connectors.
9. Remove seat from vehicle.
Old 02-26-2013 | 01:19 PM
BeachBoy's Avatar
I appreciate the information. I am going to let my garage do the work -- beyond me. I will pass this information along to them. Will the rear seats be easy?
Old 02-28-2013 | 05:25 PM
BeachBoy's Avatar
Default Decodethis says Pac is AWD
I am looking at a 2008 Pac near Pensacola, FL. I live in Birmingham, AL. I am thinking about buying it. I ran the VIN through autocheck and decodethis. Decodethis says that the Pac is AWD. I spoke to the owners. They say that they believe the car is FWD. How accurate is decodethis?
Old 03-12-2013 | 10:05 AM
Not familiar with that site but if you would like to send me the VIN number I can provide you an exact build sheet
STilt66
11-18-2011 10:11 AM
nicelydone9
08-21-2011 05:33 PM
tma20sc
06-05-2009 09:56 AM
quattj
05-24-2009 11:11 PM
ssstw1
02-10-2008 04:49 PM
