No heat
No heat
I have no heat in a 2007 pacifica. Worked good in the morning during a large blizzard. Went to go into town
in the afternoon and the blower motor is not working.
Blower motor relay or just the motor went out??? How would I check??
RE: No heat
i think u are confused about something having only hot or cold air coming out of the vents has nothing to do with the blower motor resistor or blower motor for that fact.
What is not working no hot or cold air or no air coming out of the vents?
RE: No heat
The front blower motor the heats the driver and passenger does not blow any air at all. There is another heater in front of the back passengers you can turn up also that only blows cold air. I'm thinkin that the back one may be fed by the front. So if the front is not circulating any (hot)air the only air left to move around is cold air.
Oh Ya, I'm working outside and it's neg 10 below zero....hence the cold air.
Is there a way to check the resistor to see if it is bad once it is pulled out.
davet
12-19-2007 05:18 PM
stunod2002
12-15-2006 04:27 PM
