one more timing belt question
Old 06-02-2008 | 01:00 PM
gbeach's Avatar
Default one more timing belt question
Went to dealer this weekend, the timing belt they had was a Gates belt with p/n 4792353.
oreilly auto, and rockauto.com, and Gates.com website show gates belt p/n T295. Wouldn't
these be the same belt, but Gates stamps it different for chrysler.Had the chrysler logo.Big price difference.
06 pacifica 3.5l.
Old 08-15-2010 | 10:01 PM
djetelina's Avatar
I have been researching, getting ready to change out my timing belt.
Yes, it appears that the PN's that you listed are for the same engine used in the Pac (3.5L) and both are made by Gates.
I was going to spring for the extra bucks to get the OEM part for my Pac from the dealer just in case its spec was possibly a little better, but lucked out and found it on eBay for $45 delivered cost.
Old 08-26-2010 | 01:42 PM
djetelina's Avatar
Did the Timing Belt replacement job myself yesterday (I am a typical do-it-yourselfer, no more than that). Some random thoughts & suggestions for the next guy since this is a b!#$h of a job! (had 118,000 miles on my 2005 Pacifica, 3.5L engine)
1_ I bought factory Chrysler (made by Gates) timing belt since I did not want any issues. ($40 fr eBay)
2_Bought a factory Chrysler (made in Germany!) water pump for the same reason. ($40 fr eBay)
3_ “Borrowed” a loaner Radiator Pressure Tester, Chrysler Harmonic Puller (3-jaw) and Harmonic Installer from O’Reilly auto parts. Used the Pressure Tester to test the new water pump for leaks, it is sealed by an giant o-ring and did not want to find it leaking after full assembly.
The Harmonic Installer did not work due to its design. Got a 90mm long x 12mm x 1.75mm bolt and a bunch of washers from Ace Hardware for $2.80 which enabled me to install the Harmonic Balancer.
Should you not have this, the auto parts suggested slamming the harmonic balancer back on using a piece of wood and a 10# sledge hammer (I did not try that approach)
4_ No need to take the valve covers off or disconnect the fuel line as the factory manual suggests.
5_ Do have a bottle of “white out” handy. Mark the old belt & drive cogs on the 2 cams and at the crank. Then transfer the marks to the new belt. Makes the install/timing a snap. (One cam did snap out of position after the belt was removed, but was easy to rotate back into position w/ a wrench.)
You CAN use the breaker bar on the harmonic balancer bolt to rotate (slowly) the crankshaft to TDC position.
6_I used a small tow chain w/ hook to keep the harmonic balancer from turning when I torqued it with the ½” drive breaker bar. (I did not have any air impact tools.)
6 a_Use of a floor jack to support the engine is kind of optional. It is mostly used to maintain the engine in a position such that it can be most easily worked on. At times you may feel the need for any extra ¼” of horizontal clearance, this can be obtained by using a short (3-4’ long) 2x4 board as a “pry bar” to pry the engine block towards the drivers side of the engine compartment.
7_ Have a 3/8” x ¼” drive adapter handy and a full set of 3/8” and ¼” metric sockets handy. As well as the ½” drive metric socket for the harmonic balancer (think it was 17 or 19mm do not remember precise head size, but it had a smaller head size than I expected).
8_ Do have some metric Torx head 3/8” drive sockets handy and some Vice Grips pliers. (there is 1 Torx screw on the timing belt cover)
9_ One of the most difficult steps for me was getting the power steering pump bolts back on. Was almost impossible. Wound up having to remove the radiator fan assembly such that I could push the steering pump back in position. (There is a timing cover bolt BEHIND the steering pump. I DID NOT put this timing cover bolt back in upon reassembly since I would never want to have to remove the steering pump again.) Now is the time to replace the factory installed Lower Radiator hose if you haven’t already.
9.a_ Re-installing the serpentine accessory belt can be difficult. I used the clips to hold it in place. I used a 1” wide ratchet drive “tie down strap” to pull a 12” crescent wrench attached to the tensioner to “rotate” the serpentine tensioner back. The ratchet drive strap held the tensioner back well and the belt went on without too much fighting.
9b_ I used some large “paper clamps” from the office supply store to “clip” the timing belt and serpentine belt on the drive pulleys during the install. Made things much easier.
10_ After 118,000 miles the Timing Belt still looked mighty good. But of course should it have broken the engine would be toast. Also replaced the serpentine accessory drive belt with a new Gates micro-V belt.
11_Total wrenching time for me on this job was sixteen (16) hours. (this includes time going back to auto parts store twice and replacing ALL the radiator and heater hoses)
If any questions please email me: dj at flagshiptec.com
dcotter0579
12-09-2012 11:38 PM
DaveC8656
08-26-2008 01:18 PM
06-17-2006 11:52 PM
AndreS123
10-07-2005 02:38 PM
Purbano
09-22-2005 01:58 AM
