Pacifica front end clunk / rattle noise
Old 03-01-2006 | 10:20 PM
rtp's Avatar
rtp
Default Pacifica front end clunk / rattle noise
Hi everybody,
We own a 2005 Pacifica we love but there is something who pisses me off. The front end CLUNKS / RATTLES !
That happens at low speed, when driving over small potholes, especially on the passenger side.
The 4 used Pacificas I drove, all of them did the same thing.
Was somebody able to get rid of this "feature", or I am stuck with it forever ?
Old 03-02-2006 | 11:45 PM
014x459's Avatar
Default RE: Pacifica front end clunk / rattle noise
There are a lot of TSB's for front end noise on Pacificas. They range from lower control arms, to PTO units that make clicking noises. The sway bar links and struts make noise on them. I would go to a dealer if your still under warranty.
Old 04-09-2006 | 08:22 AM
Bajavicki's Avatar
My 2004 does the same thing........................
Old 04-16-2006 | 03:45 AM
jgralka's Avatar
I have the same problem with my 04. I finnally got chrysler to buy it back. We pick up our new T&C in a couple of weeks. Good Luck guys!
Joe
Old 07-30-2006 | 09:38 PM
XtremeCuztoms's Avatar
typical wearable item............................. front strut bump stop's or jounce stop's.
in the boot on the strut you will find the issue.
the TSB related pays very good even under warranty. MOST dealers have the set of chassis ear's or electronic ears that make finding the issue very simple.
if i had noise in a CS front end i would do....................Lower Control Arms, Links & Bushings, Bump Stops, and if AWD i would do PTO....
all these parts we keep very large amounts of in stock at all times.
good luck...
Xtreme
Old 01-29-2007 | 06:05 AM
ricvilla71's Avatar
I just noticed a strange noise in the 05 Pacifica that we just bought. I can only hear it when turning, particularly to the left. It is a clicking/flapping sound. I originally thought that it was coming from the back of the vehicle, but since it only occurs when steering, I am almost sure that the sound is traveling from the front end of the vehicle (sorry, it is hard to determine). I am going to take it to the dealership since it's still under warranty, but was wondering if anyone could contribute with some TBS to be used as guidelines.
Thanks in advance for your help
Old 01-29-2007 | 11:53 AM
if the dealer is worth there salt they will know this stuff already
Old 01-29-2007 | 10:14 PM
shnormo's Avatar
Since they do use CV shafts, they could be binding.
Old 02-19-2007 | 08:01 PM
ricvilla71's Avatar
Just as a follow up... it turns out that the problem was the rear differential requiring "normal" service. The noise was indeed coming from the back of the vehicle, and itis now completely gone...
Old 03-26-2007 | 08:19 PM
tcoxcsr's Avatar
I mentioned some clucking I was hearing when I had my car in for service -- turns out the strut assembly was defective and had to be completely replaced. They said there was a bulletin on it. Thatwarranty I boubht just (almost) paid for itself!
