Pacifica Idler pulley
Old 07-22-2012 | 10:37 AM
Belpac05's Avatar
Default Pacifica Idler pulley
I have a 2005 Pacifica, that needs the lower left serpentine belt idler pulley replaced. Any suggestions on removing it completely, there is not enough room between the engins and frame, for it to come out with the bolt all the way loose. if I only have another 1/4 inch it would come out. undoing the motor nount and raising or lower engine still did not clear the frame
advise is appreciated
Old 12-18-2020 | 12:15 PM
ExecCAC's Avatar
Jack the engine up a bit, and pulley comes right out
Old 12-19-2020 | 10:31 AM
djetelina's Avatar
On the Pac's with the 3.5 engine the idler pulley does lack about 1/4" clearance to be easily removed. Using a piece of 2x4 lumber the engine on rubber mounts can be easily shoved over toward driver's side direction to gain the required clearance,thanks to flexi rubber engine mounts .
Dtdp95
08-23-2020 05:03 PM
marcpilot1
11-01-2019 12:55 PM
itsJames2011
04-23-2017 07:23 PM
Jalvarado6868
10-16-2016 10:34 PM
Jerzeemommy
10-16-2009 05:12 PM
Quick Reply: Pacifica Idler pulley
