Position Lights / Interieur Lights
Old 06-17-2007 | 03:51 PM
bumu's Avatar
Default Position Lights / Interieur Lights
Hello,
just a question. My 04 Pacifica AWD has small lamps in the upper corner of each headlight. Also there are small bulbs in the lower corner of the rearlights. Are these lights positioning lights or whatelse? How can I enable these lights? My car was imported to Germany. Could it be that there is a switch or fuse to enable / disable them?
My other question is: Are the buttons on the steeringwheel normally illuminated or not? Is there a bulb in the steering wheel?
I hope somebody can give me some tipps.
Best regards from Germany
Markus
Old 06-17-2007 | 05:14 PM
xfire04's Avatar
Default RE: Position Lights / Interieur Lights
no lites in steering wheel not sure about the outside lites
Old 06-18-2007 | 08:36 AM
BenjaminA's Avatar
Last night I just noticed the little "side" bulbs in my headlights as well. Are they burned out blinkers?
Old 06-18-2007 | 10:24 AM
xfire04's Avatar
they should lite up when your turn lites on they are side marker lamps
Old 06-19-2007 | 11:35 AM
bumu's Avatar
Pacman: They do not get on with the markers! I tried this also! I think they are "day lights". In the US most of the cars have lights which are on all the time - day and night. In Germany this is forbidden, so I thought there is a way to enable them again.
Does anybody know for what these bulbs are?
Old 06-19-2007 | 11:37 AM
bumu's Avatar
Pacman: I missunderstood you! But also when the light is on they do not lite up.
Old 06-19-2007 | 03:35 PM
xfire04's Avatar
when my lites are on the side marker are amber in color i think in germany amber side la mps are not allowed so might be disconnected
Old 06-19-2007 | 09:33 PM
xfire04's Avatar
where in germany are you im planning to bye a crossfire that is built their i live in florida
my name is dennis need your responce
Old 06-23-2007 | 08:37 PM
xfire04's Avatar
het bumu are you still out there
Old 06-28-2007 | 12:06 PM
BenjaminA's Avatar
I figured it out.
They only come on when you remove the key and exit the car. They come on to help light your path.
The replacement bulbs are like $2.89 US
sumncguy
04-17-2012 08:27 AM
jimhild
03-18-2008 04:45 PM
jjmenard
09-06-2007 06:33 PM
mr.belvedere1954
07-29-2007 04:16 PM
karpond
01-26-2007 10:21 AM
