Rear Carrier '06 Pacifica Replacement
Old 01-07-2010 | 08:30 PM
B_rad1969's Avatar
Default Rear Carrier '06 Pacifica Replacement
I got a replacement carrier today. I'm still working on getting the old one out. Question on getting the axle's out... I used a pry bar to pry out the axle from the carrier. Problem is they wont come out far enoughto drop down. How do I get the rear axle to move so I can get the old one out? And I'm sure I'll see when I get them out, but, what holds the axle in the carrier and how easy is it to get the axle's back in the new carrier?
Thanks for the help.
This is not a fun job.
Old 01-08-2010 | 05:32 PM
drn151's Avatar
Have you removed the rear wheel/hub from any A arms or other suspension componets that would interfer with the removal of axle from differential?
Old 01-08-2010 | 06:01 PM
B_rad1969's Avatar
There are 5 or so bolts that hold everything on. There is a cv by the carrier and on the other end of the axle. I don't see a way to get them pulled out enough without taking apart all of the suspension. There has to be another way. I know they make it tough to work on, but not this tough.
cpotter638
11-07-2012 02:16 PM
thehappygiant
01-18-2009 12:23 PM
smaerten
09-24-2008 04:30 PM
walight01
11-22-2007 11:24 AM
jjmohan
05-14-2007 03:15 PM
