Rear Wiper Arm Adjustment
Old 11-04-2010 | 09:05 PM
Blitzn's Avatar
Question Rear Wiper Arm Adjustment
The rear wiper arm on our 2005 Pacifica basically swung 180 deg from the horizontal position in a nice arc on the rear window.
On our 2008 Pacifica, the arm is angled downward about 10-15 deg so it clear a "crooked semicircle".
Does anyone know how to adjust this sucker - or remove and reinstall so it is level?
Many thanks!
-dennis
Old 11-05-2010 | 07:55 AM
busboy4's Avatar
Dennis,
I have not worked with my rear wiper, but it should be the same as up front. Carefully pop up the plastic cover at the base of the arm. Remove the nut that holds it on the shaft. Remove the arm from the motor shaft - can be tough. A little PB blaster can help. Once off you can rotate the arm a few "teeth" on the splined shaft of the motor to adjust the throw of the arm. Re-install the nut and close the cover.
calamity coyote
06-30-2015 08:13 PM
TheAverageDan
06-03-2015 06:02 AM
kdavidson
04-08-2014 04:18 PM
notodd
03-12-2012 03:47 PM
SpudlerT+CTouring
10-20-2011 04:28 AM
