Replacing the Oil dipstick tube
Help....My oil dipstick broke off in the tube and its stuck. I tried everything to pull it out but its stuck pretty good. I would like to just replace the tube. It this easy? I can see the upper bolt but not sure if there are other bolts under the car. Can someone give me instruction on replacing the tube. Thanks
Not sure about the Pacifica engine but it's probably similar to the Sebring 2.7 since it's a similar function. On the Sebring, there's just one bolt near the top. The tube fits into a hole near the bottom and has a couple of O-rings to seal it down there. To remove the tube, you need to remove the bolt, then pull up on the tube to get it out. It was stubborn, and I needed to use a prybar carefully under the metal strap that the bolt went through. With a little leverage for persuasion, it popped right out.
Clean up the bottom end as well as you can. I searched several auto parts stores but never found replacements for the O-rings so I re-used them. Put a little clean oil on the O-rings before pushing the tube back in place.
I tried this and my dipstick kept pushing farther down
