Running a wire Trough The Firewall
Old 06-06-2011 | 07:34 PM
WRXCarl's Avatar
Cool Running a wire Trough The Firewall
I'm trying to run a wire for a speaker for a PA system I'm working on through the firewall but cannot find a way through. Has anyone done something similar or can you tell me where to run a simple wire through?
The Car is a :
2005 Chrysler Pacifica 3.8L FWD Base Model
Thanks in Advance
Carl
Old 06-06-2011 | 08:21 PM
Djinn-n-Tonic's Avatar
remove the left side inner fender liner, and follow the factory harness into the grommet. That will leave you about 8 0r 10 inches up the left kickpanel.
Old 06-09-2011 | 02:56 PM
SARG's Avatar
I snaked several wires down through the side of the firewall on the passenger side. Passes around the side of the wall alongside the inside of the fender. From the inside pull down the liner under the glove box and you'll see the easiest path.
I ran several wires while I was at it .... and sure enough I have used them all now for lights etc.
Old 07-11-2011 | 02:16 AM
WRXCarl's Avatar
Thanks for the responses both sound simple just need to find the time to do this now ... busy busy busy
Old 04-10-2015 | 10:46 PM
Tower Master's Avatar
Default installing fog lights
Just saw this info, I would like to try this on some fog lights in the future. I will have to remember this.
Thanks people.
Old 04-11-2015 | 06:32 AM
salvonrico@verizon.net's Avatar
Thumbs up Fog lights
Just saw this. Will work great for me. Thank you guys, for the tip.
Old 04-17-2015 | 05:08 PM
kcunning728's Avatar
Default Running wires
Well as it be. My 07 Pac was prewired from factory so all I had to do was order the turn signal switch with the foglight switch on it. But I will do this option to wire up another mirror that has a compass and thermometer.
ecfilms123
03-25-2011 11:53 AM
linkpost
01-28-2008 05:09 PM
jdcollins
07-18-2007 09:56 PM
perryrtman
01-02-2006 06:46 PM
belair327
12-25-2005 03:45 AM
