Sticky Gas Pedal
Sticky Gas Pedal
05 Touring AWD 3.5L
When driving or just starting out from idle, it seems to take an abnormal amount of pedal pressure to get it to move. Once you get to the 'break over' point, the amount of pressure seems normal. Checked out the linkage at the engine side - cables don't seem kinked or dirty. I have tried silicone spray on the cable, doesn't seem to fix it.
Would that fix the binding? The throttle response once you get it over the hump seems fine.
Now..pop the air cleaner off...and look inside the throat..see all that brown/black TAR? that is what is binding your throttle. once the plate passes the GUNK, it will operate fine.....
Carb cleaner, throttle body or Air induction cleaner , or even Brake parts cleaner, can be used with an Old Toothbrush .(Trust me, I say old , because you arent going to want it back after this.. ) and you'll be good to go.
Thanks for the tip Gentlemen.
We had just started experiencing the issue intermittently. I used brake cleaner sprayed onto clean paper towels and gently cleaned the throttle bore and the throttle plate edges. Everything moves very freely now.
A DIY travel tip: I used a 24" length of 1X2 between the front edge of the driver's seat and the accelerator to hold the throttle wide open for easy cleaning.
I have cleaned mine three or four times now and it still seems sticky. Is there a gasket between the throttle body and the intake? I was thinking of removing it to clean the back side of the plate. I don't want to take it off if I don't have a new gasket to replace the old one. Very tough to see up inside to make sure I got it clean enough.
