Trans Fliud Change
Old 03-18-2009 | 11:38 PM
Pacifica3.82007's Avatar
Originally Posted by kgillespie
Also, I read somewhere that it is a PITA to change the fluid in the Pac. Is is any worse than any other car. From my experience, it is never fun. But I was told it was a PITA to change spark plugs on the 3.5 and it turned out to be one of the easiest I have done.
I'm not sure about the fluid question, but I think new fluid with it's "highly modified friction" additives is the way to go.
I read that the motor mounts have to be loosened to get to some hidden pan bolts. I didn't have time or I would have done it myself. So, I opted for the flush method.
  #22
Old 03-19-2009 | 07:34 PM
mrfixit454's Avatar
Sorry, I forgot I posted this. So I need to change the fluid, no big deal. One more question, in a work fan I had, ford winstar, the tranny started slipping right after I bought it with 110K on it. I called ford and they said if it had not been changed do not to change the fluid now. They little pieces of clutch material in the fluid was acting like the friction surfaces and new fluid would cause it to slip more.
My question, with 80K and no problems, will I cause any problem changing it.
Can't speak for Ford but what you speak of did happen in my Mom's 86 Buick Century. She had tranny problems and a shop changed the fluid and after getting home, the fluid change made it worse. The dealer at that time said it was possible.. I had never heard of it before. She had to have the tranny rebuilt. I am not sure how many miles it had at that point in time.
aggiejet
06-30-2012 04:22 PM
flaxman
09-05-2011 03:10 AM
parlayjay
04-18-2010 04:28 AM
Pacifica3.82007
02-26-2009 09:16 PM
Tony24md
12-15-2005 01:11 PM
