Transmission Leak
Old 10-14-2011 | 01:18 PM
cowli4nia1's Avatar
Default Transmission Leak
I was currious if anyone has experienced leaking transmission fluid for the cover that I highlighted? If not, does anyone know if I can just drop that pan and reseal?
Old 04-06-2013 | 12:25 PM
sorin1307's Avatar
Hi there,
I have the same problem? I just noticed last night, did you fix it? Is the seal or something else.
Thank you
S
Old 04-06-2013 | 07:21 PM
Djinn-n-Tonic's Avatar
A few things come to mind.......
Make sure the leak is NOT coming from the Axle seal housings,or the PTU joint. since fluid doesnt Leak in an UPWARD direction, it can be very easy to mistake a leak at the diff cover from fluid that has "Blown around From driving.
Next remove the cover and ensure the housing isnt cracked (Somewhat common)
The good news is.... If youre sure it is a cover leak, reseal it with RTV silicone and call it a day. There is no gasket available, and there never was, rtv was used from the factory.
Old 04-12-2013 | 02:25 AM
lilrobert1's Avatar
wont let me view pic ? sounds like same issue I have is your a front wheel drive
farmerbob02
04-13-2011 01:04 AM
billbon8
09-01-2008 01:49 PM
hammerdown72
04-05-2008 08:10 PM
fyrepower
11-16-2007 08:44 AM
Daryl Baines
02-25-2007 05:38 PM
