Transmission problem or pcm problem?
Old 06-19-2012 | 07:59 PM
jminter's Avatar
Default Transmission problem or pcm problem?
The problem im having is is the car is in any gear r n or d at a complete stop the speedo shows the car is going 20 mph i put it on a transmission computer it shows the output seed sensor is showing rpms when it should show 0 so i replaced the output sencor and its still doing the same thing one shop said it needs a new computer others say they want to tear into it to see if it is a tranny problem please help if you can thanks
Old 06-11-2019 | 03:17 AM
calcala12's Avatar
Hi @ebrennan, where you able to get this issue resolved? I'm currently experiencing the same issues. I have changed both blend door actuator and still the same issue. I got an electrical diagnostics perform and they found an issue with the recirculation actuator no responding reason I change both under the glovebox.
Old 07-03-2019 | 11:14 AM
pac220's Avatar
Search this forum for this issue and you will see, like I did, that the alternator is to blame.
I took my '06 Pacifica in with this issue, it revved to 20 mph at a stop, but wouldn't go over 40 mph on the road.
My mechanic said it was the transmission, so I got a new solenoid for $500.
Drove it out the door and it still did it. I took him 10 Chrysler forum comments, and lo and behold, he decides it's the alternator.
I haven't had the problem since.
TravisAz
02-14-2022 04:42 PM
James Dinkins
11-06-2017 04:51 PM
SpaztasticSam
12-22-2016 04:00 PM
grifkac1
03-22-2015 04:33 PM
msmarvel
08-16-2007 12:15 PM
