Transmission Service
Old 04-07-2009 | 03:13 PM
bizzob223's Avatar
Default Transmission Service
I have 72k miles on the car and I took it in for an oil change to find out that I have a shift solenoid leaking. Also I am due for a trans service. I want to chagne the fluid out and was wondering if anyone knows when they replace the shift solenoid with the have to drain the pan and replace the fluid? If not should I have a flush done on the trans ot just drop the pan and change the filter and oil in the pan? Its not shifting rough or anything, just thinking preventative maintenance.
Bob
Old 04-07-2009 | 11:27 PM
the sol pack is up top only loose a cup or so when changing it.
Drop the pan replace the filter.
Old 04-08-2009 | 11:26 AM
bizzob223's Avatar
OK thanks. Any idea how many quarts I will need to replace the fluid lost when I drop the pan? Also what brand of filter should I buy? And do they usually come with gaskets or use RTV?
Bob
Old 04-08-2009 | 11:55 PM
1 qt U use mopar so I have no opinion to other filters and use RTV
Old 04-13-2009 | 10:48 PM
indept's Avatar
Only 1 qt when you drop the pan & change the filter, sounds awful low?
LG300
02-19-2015 08:10 AM
Edo300USA
04-14-2012 02:25 PM
optimusprimer
01-06-2012 11:54 AM
redfin123
12-02-2008 09:38 AM
tshall
07-05-2008 02:32 AM
