trouble shooting trailer wiring harness
Old 05-14-2008 | 01:18 AM
georgeo's Avatar
Default trouble shooting trailer wiring harness
Hello All,
I am having a problem with a 2004 Pacifica trailer harness. The brake lights work on the vehicle but not at the plug. I am making the assumption that the harness combines the turn signals and stop lights. Any help would be appreciated.
georgeo
Old 05-14-2008 | 12:58 PM
Default RE: trouble shooting trailer wiring harness
did u use chryser wire harness or aftermarket one?
Old 05-14-2008 | 05:55 PM
Sierrasan's Avatar
ORIGINAL: georgeo
Hello All,
georgeo
The harness takes power directly from the power distribution box in the engine compartment not from the brakes/turn signals so they can work but they willnot trigger the trailer lights if the supply fuse is blown in the PDM. Check for a blown fuse #10.
Old 05-14-2008 | 10:14 PM
georgeo's Avatar
Yes sir, it's a Chrysler harness. The numbers on the tag read 82208221 and 23489A if that makes a difference. Using a test light, I get power for tail lights, one with constant power ( don't remember which one) and both turn signals but no brake.
georgeo
Old 05-14-2008 | 10:21 PM
georgeo's Avatar
ORIGINAL: Sierrasan
[/quote]
Hello Sierrasan,
Thanks for the tip , I'll check it in the mornig and report back.
georgeo
Old 05-15-2008 | 10:04 PM
georgeo's Avatar
Checked the number 10 fuse ( blue 20a) and it looked good and has continuity. Anything else I should check?
georgeo
AZ_Ron
09-16-2012 08:07 PM
bettyboop
04-08-2012 12:22 PM
spotmaticf
06-23-2010 09:59 PM
rpdenney
11-18-2008 05:24 PM
mrrbby
04-30-2008 08:16 PM
