Water in Light assembly
I have water on the inside on my RH light assembly. No cracks, submersion, in fact I don't really drive that much lately. Not signs of water intrusion thru the back since I have after market HID lights but the rubber boot fits correctly. Not much rain while driving to maybe force water in from some point.
I removed it from the car, remove the bulbs, added some water to see if anything came out. Nothing. Added a bit of detergent to remove any dirt that may have crept in and now drying with a small fan to move air thru to dry it.
Any ideas?
Any ideas?
RE: Water in Light assembly
Could it be condensation that has formed this water? If the headlight housing isn't sealed properly the smallest hole can allow moisture in and create a puddle over time. The way you're talking it sounds like more water than this but I would check for any small holes and fill them with silicon. Good luck!
It was a puddle and so not just condensation. I poured out about a 1/4 cup. I did fill, not completely, with water to see if anything leaked where the lens is attached to the body. No drips. I have dried and re-installing it. Thankfully it's very easy to remove if it happens again. I don't want to fry my Pilot HID system due to moisture.
Martyj160
05-14-2012 04:35 PM
dmbeale
15
11-24-2010 07:26 PM
captain catfish
10-02-2010 05:32 PM
musicfreak2195
07-07-2009 03:23 PM
