2007 PT. Radiator Fan
Radiator fan will not run at low speed or high. The vehicle has a TIPM so no individual relays. At switch there is power at pin 1 and nothing at pin 2 or 4 for HS and LS. Don't want to just through parts at it plus TIPM is expensive and I do not know how to set it up for my vehicle if this is the issue. Does the car need to be running to test HS and LS going to try that tomorrow.
1) change your font color back to default.
2) there's a pair of relays on the fan shroud itself.
3) there's a bulkhead connector usually at the bottom of the shroud as well, that connects those relays back to power and TIPM.
4) where in NJ are you
David Echeverry
11-22-2020 08:16 AM
David Echeverry
11-21-2020 03:43 PM
ulyman
08-07-2009 09:18 PM
