disc brakes rear
To be completely honest, the upgrade isn't worth it. If you want the looks, I suppose if you found a wrecked PT in the junkyard that had rear discs you could steal the swap off of it. You'll need the rear hubs, the rotors, the calipers, all brackets that your car does not have or will not fit the brakes, and of course the lines. I believe your e-brake cable may need to be replaced also. But all the work involved for an autocross brake setup? Nah. Not worth it for a street driven car. Maybe if you were autocrossing it all the time, would this upgrade be remotely worth it, but I think even in autocrossing you can get away with a good front brake setup and a mild rear upgrade on the shoes.
Tutts.inc
09-19-2013 11:17 AM
ramrod2009
04-24-2011 01:24 PM
