05 T&C Died & Won't Start
Old 03-08-2006 | 11:00 PM
chris banks's Avatar
Default 05 T&C Died & Won't Start
I have a 2005 T&C with the 3.8 liter. It has all of 41,000 miles on it and has been babied. It died on the road today and will not start. It turns over and is getting spark. Has anyone had a similar problem? Also, is there a fuse panel on the inside of the van? I know have found the fuse/relay panel in the engine compartment, but I can't find one inside the passenger compartment. Any suggestions would be GREATLY appreciated. Thanks in advance.
Old 03-09-2006 | 05:24 AM
TandC's Avatar
Default RE: 05 T&C Died & Won't Start
It could be many things including a bad fuel pump.
Old 03-09-2006 | 07:30 PM
oldchina's Avatar
Definitely sounds like a fuel problem. You should also check the immobilizer circuit. I had trouble with it on a 99 Jeep I had. You still have warranty though and free towing too. The only fuse panel I'm aware of is under the hood. Doubt if it's a fuse though.
PSD4life
09-27-2011 06:22 AM
dja4260
04-24-2011 10:43 PM
aaronsedge
02-05-2011 12:14 PM
laura
04-11-2010 09:48 PM
bobp53916
07-17-2007 01:23 AM
