06 T & C air bag light stays on
Old 07-06-2009 | 03:05 PM
skidip1's Avatar
Default 06 T & C air bag light stays on
I have a 06 Town and country, I recently had the rack and Pinion replaced, and when I got the van back the air bag light stays on, horn will not work when pressed on steering wheel, but it will sound when remote lock is pressed, and cruise control will not work,,,,I have read in a couple of other threads that this problem could be the clockspring, but I don't know why this happened when the rack was replaced, and I read that this was a warranteed item on some models, but do not know if it is covered on an 06 model,,,, and was wondering if there was a wiring plug that had to be unplugged when rack and pinion was replaced that maybe was left unplugged
Old 07-06-2009 | 03:59 PM
more then likely a clock spring is broken inside.
Old 07-06-2009 | 06:45 PM
skidip1's Avatar
do you know if that is covered under a recall?
Old 07-06-2009 | 10:20 PM
there is no recall for an 06 van and a clock spring.
Old 07-09-2009 | 01:41 PM
skidip1's Avatar
thanks,,,,,do you know what the actual part name is, for a clock spring?
Old 07-09-2009 | 09:43 PM
clock spring is the name
Old 07-17-2009 | 03:37 AM
Master Chief's Avatar
This is unrelated to your specific problem, but just for people having a related problem and looking for clues: A blown fuse, or a bad connection in the fuse box might cause the air bag light to go on.
I recently pulled the first fuse in the fuse box, which broke because of corrosion and thus I had to remove all fuses and relays, and cleaned the two fuse jumpers (the pins below the black plastic plate where the fuse pins are inserted). Problem resolved – my local Chrysler dealership checked the airbag and everything is fine they told me.
Old 07-17-2009 | 09:48 AM
"horn will not work when pressed on steering wheel, but it will sound when remote lock is pressed, and cruise control will not work"
Clock spring there is not a fuse for this stuff on an 06 van.
Old 07-26-2009 | 10:20 PM
Torancis_Chrysler's Avatar
Old 08-05-2009 | 09:06 AM
skidip1's Avatar
Default thanks everybody
Thanks everybody for the advice about the clock spring problem i was having,,,ya'll's advice helped me fix my problem,,,,thanks again !!
dannyboyindc
03-05-2015 06:51 AM
jpiper4@cogeco.ca
07-24-2012 03:43 PM
debbie210363
01-24-2007 08:48 PM
jmazza
12-08-2006 08:18 PM
jmazza
09-15-2006 08:57 PM
