07 TC Air conditioner not cooling
you're on the good path.
if you have no pressure, there must be a leak.
bad news, you have to pressurise the system if you want to find where it's leaking. but this time, together with R134, the mechanic will put in fluorescent colour.
so when it starts leaking, you will be able to see that spot with special goggles.
no other way to fix it.
once you find a leak and you fix it, things go all over again. pressurize, start the AC, try to find a leak....
ususally, there is only one place to be fixed.
also, that colour is not expencive, about 10% of the gas fiiling.
that chill treatment, you don't need it if AC is working properly.
wouldn't know about conversion.
Fortunately, the warm weather is a way off so I have time.
Thanks for your suggestions.
Deke
Deke
You might want to read about the pressure transducer (switch). It may be too cold for you to be trying to solve this? Not an expert but you are 10 degrees off from the operating temp that protects the system. read these..
http://picasaweb.google.com/lh/photo...eat=directlink
Also... I only see mention of reading any pressure on the high side not much talk about the low side. If you don't have one, a manual on CD from Ebay might help you out tremendously.
#15
I'll attempt.
He is trying to check his A/C. Ambient temp just got up to 50 deg in his area.
No pressure high or low side. Compressor is not engaging (I think). Maybe his gauges are not working right? Maybe it is too cold out to tun the A/C. Was reading some test efficiency tables in the manual and the lowest temps in the charts were for 70deg.
#17
I'll attempt.
First, I have not been able to get the compressor to kick on at all. I do not yet know the high side pressures as I need R134 adapters for my gauges and they haven't yet arrived, but should shortly. The low side reads zero with engine running or off, but I'm not real sure I trust the cheapo Kmart gauge that came with a can of $134a.
Outside air temps in 40s and one day 50s, not sure what the inside ambient temperature is. Obviously the AC system should be reading inside ambient air, correct? What temp should the ambient inside temp be for the compressor to kick on?
I can find no evidence of a leak anywhere and the car is relatively new with low miles.
Could it be that everything is OK, that I just don't have the temps for it to operate? Should the AC kick on if I turn on the defrosters?
As soon as my adapters arrive I'll report both high and low pressure.
Thanks,
Deke
07 TC Touring 3.8L 51k miles
northeastern Michigan
#18
No AC
Outside temps 50s
Compressor does not kick on
Low side pressure zero, engine on or off
High side pressure unknown until adapters arrive
No evidence of leak anywhere I can find.
Must inside ambient temp be above certain point?
Tnx,
Deke
#19
Fox
temperature may be minus 1 000 degrees, you MUST have some pressure inside the AC system. when the engine is OFF, pressure is more or less equal on both sides. only when AC is ON, then you have different pressure in low press.part then the hihg press. part.
no pressure = no AC. no cooling, compressor is not running.....nothing.
#20
Fox
More than likely, I have a giant leak somewhere, but so far I haven't been able to locate it. Perhaps one of those leak detector kits with the dye, glasses, and UV pen will help, but I would think that I should be able to see it without a kit. Sure is puzzling.
Anyway, thanks again for the support. I'm not the type to give up as long as I can keep trying something new and I'm not out of ammo yet. What I need to do is get it up on a rack where I can follow every line. I've also ordered a repair manual that may be of some help.
Deke
07 TC Touring Walter P series51k
