16 inch rims
My 98 wear 16's from the factory - I think a lower profile tyre on the 16 cancels out the larger rim
you can put on 16" no problem. The correct tire size is 215/65/16. then all you need to do for the speedo is change the pinion factor. this is a menu of tire sizes and all you do is change to the new tire size and your speedo will be right on.
SACUSTOMS1
05-22-2007 11:04 AM
rson05
03-17-2007 12:38 PM
