1988 dodge grand caravan check engine code
Old 08-24-2006 | 06:53 PM
contourfreak22's Avatar
Default 1988 dodge grand caravan check engine code
hi i have a 1988 dodge grand caravan with the chrysler 3L. i did the check engine light blink test and the codes came up 1,2,1,3,5,5. if anyone code tell me what those codes mean.
Old 08-24-2006 | 07:56 PM
moe's Avatar
moe
Default RE: 1988 dodge grand caravan check engine code
the codes are really 12,13, and 55 the first code means you disconnected the battery.the second one is the map sensor with is causing your car to run like poop.or not run at all. the third code is the test is over (55) here's a trick try starting the car with the Map sensor disconnected.it should start.but run like poop.let me know MOE!
Old 08-24-2006 | 08:10 PM
sorry im new to this but what is a map sensor and where is it located. i heard 55 is a transmission problem.
Old 08-24-2006 | 08:17 PM
u mean the maf sensor? when i start it it runs with out it for like 30 seconds then the idle will go down and up acouple times. then runs normal has alittle sputter when reving it.
Old 08-24-2006 | 08:34 PM
ok i did it again 11,12 and 55. i notice when i turned the ignition on the tach moves too and when i did the check engine light test moving the ignition back and forth 5 to 6 times the tach went around in circles.
Old 08-25-2006 | 04:26 AM
i found the map. i unplugged it and ran it it rand the same. so im guessing this is the problem.
Old 08-25-2006 | 01:31 PM
moe's Avatar
moe
the map senson was a comon problem back in the 80s..the tach moving around might be because its going into a test mode. we use test equip at the dealer ship.this method is really old school but will get you in the area.make sure you change the vac line to the sensor. let me know MOE!
Old 08-25-2006 | 03:36 PM
ok so i will change the map sensor with the vacume hose and see what happens.
Old 09-05-2006 | 09:34 PM
ok replaced the map sensor from one in the junk yard sorry not rich enough to buy a new one. also they said the code was too thatr some ignition thing when u take the distribrutor out they said something in there or on there needs to be replace to help the missing ideling. i start the van up for awhile runs normal for 5 secongs then the idele will go up and down then stops but the light is still on and i need this van asap to move 900 miles away and i gotta make 2 trips. anyone have any ideas?
Old 09-05-2006 | 09:43 PM
ok i did the codes again i got 12 and 14 and 55 but i know 55 is the battery thing.
