2.8 CRD Radiator replacement instructions/guide
In a word, no! I paid someone else to do it. He said it was a pig of a job. Be sure you replace the antifreeze with HOAT type in 50/50 solution. Comma make "Go-5" which is the right one. Almost certainly you'll find the thermostat is jammed open (as it is arranged to do with overheating). While it's all apart, makes sense to test it at least.
Leedsman.
Leedsman.
not done one myself, but the procedure is in the service manual and 7a - 20 and can be found here Index of /pub/chrysler-dodge/manuals/Service Manuals/2005_RG_Town&Country_Caravan_Voyager_Diesel_Versio ns_Include
Regards
Richard
Regards
Richard
BTW, if the 'stat IS jammed open, you can save money by adopting my "Fitting a second thermostat" posting which appears to be helping members to fix poor heater problems etc. currently. This second 'stat costs around £5.
There is another factor -- one member here replaced his original 'stat following all the proper procedures, only to find it started leaking later. Is this a case of "letting sleeping dogs lie"?
Leedsman.
Leedsman.
Not done radiator
Done thermostat at week end it was stuck open and aux heater constantly on and temperature never gone up more then a quarter
Took me 3 hours remove wiper blades and wiper motor support. remove air filter housing and to have more space around the thermostat remove the hose from air filter to turbo (access to clip around the turbo from under side removed under cover)this will give you plenty of space to work around the thermostat not difficult just time consuming
Hope this helps
Hope this helps
chrysler2001
12-31-2014 12:48 AM
chamuko1967
05-03-2010 12:32 PM
96SebringJxi
10-28-2007 12:26 PM
CKdoubleU
05-08-2007 10:09 PM
