2000 grand voyager starting problems
Old 10-12-2011 | 08:45 AM
ruckshun's Avatar
Default 2000 grand voyager starting problems
Good morning, I have a 2000 grand voyager. Over the weekend I was driving as normal and when I parked and went back to drive my van hesitated to start when i turned the key, I thought it may be the battery cables so i jiggled it and she started, later on same thing but this time nothing. I have lights horn etc, I gave it a jump and still nothing. When i turn the key i get the hum and a click and nuttin else. Im not getting the usual click click click for a stater problem or the alt problem noise. I let it over nite went back and she started fine. I changed the starter relay and the same thing happening, she would start fine, i would drive around come back and try to drive again and nuttin. if i leave it overnite she would start in the morning. I am baffled, any suggestions?
Old 10-12-2011 | 10:53 PM
need to know engine size
when it wont start next time hit the starter then see if it will start up.
Old 10-13-2011 | 11:37 AM
ruckshun's Avatar
3.3 engine
Old 10-13-2011 | 04:20 PM
Raptor 07's Avatar
First make sure the "hum and a click" is coming from the starter relay or the starter. If that's the case it eliminates the control side of the relay meaning, the PCM, TRS, security system, ignition switch and all it's associated wiring. That leaves the output side of the relay meaning the battery, battery cables, starter and wiring.
Old 10-14-2011 | 08:23 AM
ruckshun's Avatar
that sounds good to me thank you. To be continued...............
BrianF
11-13-2013 02:22 PM
Michael T
10-05-2013 07:15 AM
voyager78
07-10-2010 09:03 AM
RussellF
06-28-2009 03:52 PM
penelope pitstop
12-07-2007 05:30 PM
