2000 T&C instrument cluster, mini-trip computer and compass not working
It all started with the van not starting, i was told to change cluster so i did and it fixed the problem for short time, then i hear to solder the broken pin. Done! Started working again, then thats when the rest of the problems started. I have read many things into this instrument cluster problems, I have replaced my instrument cluster three times, soldered the broken pin on the cluster, changed fuses ,added extra ground to the battery and still no cluster working, my heat will not adjust, the mini trip puter dont work. IS there a fix for this? I cannot seem to find a solution for this. I heard the BCM can be changed but seen allot about it not working? HELP!
Devin
Devin
rollinsr99
12-03-2014 03:33 PM
praasch
07-24-2009 12:01 PM
