2000 T&C Pulsating Brake Pedal
Old 03-11-2007 | 07:08 PM
Fred D's Avatar
Default 2000 T&C Pulsating Brake Pedal
Hi,
I need help! I'm going crazy. My brake pedal is pulsating when applied. I have recently replaced the rotors (they've been turned and are true), I've replaced calipers pins and guides and new pads. I have checked the rotors for runout on the hubs and only have .002 runout (within spec). I have also replaced the rear brakes. Cut the drums and new shoes were installed. I still have a pulsating pedal.
What could be wrong? Please help.
Thanks,
Fred
Old 03-12-2007 | 12:47 AM
Default RE: 2000 T&C Pulsating Brake Pedal
nothing if u did all the stuff u said u did then xomething else is a miss or was done wrong. Who did the work ne way? calapers wont be pulsing so that was a wast of money. Slide pins same thing. Are u doing this at high way speed then applying th breaks or low speed applying them? When hot worse?
What rotors did u get aftermarket or factory ones?
Old 03-12-2007 | 02:00 PM
Fred D's Avatar
Thanks for your help. I figured out my problem last night. I have two T&C's 1996 and a 2000. The Brakes on the '96 do not pulsate. The only thing I have not checked are the rear drums for runout. I should not have to I thought because I had them turnned. So I deceided to take the drums off of my "96 and try them out on the 2000. Guess what I found out?? The brakes do not pulsate with the '96 drums. I dont understand how the machine shop guy messed them up. But he did.
Thanks again,
Fred D.
Old 03-13-2007 | 03:15 AM
ne one can do that if they dont know how to set the machine up they can end up making it worse
monsterdub
05-05-2024 12:10 PM
Mark
12-10-2014 10:13 AM
Harijs Pludums
07-22-2014 11:06 PM
jgstudios`
02-24-2011 02:34 PM
posjr
01-18-2007 02:52 AM
