2001 Chrysler Grand Voyager SE RG PCM in Sydney Australia?
Old 07-07-2011 | 06:18 AM
ajhoward's Avatar
Default 2001 Chrysler Grand Voyager SE RG PCM in Sydney Australia?
Hi there,
I own a 2001 Chrysler Grand Voyager SE RG, and the fault code P1684 is coming up and P0601 is also coming up, but not everytime. I read up on this and found that I apparentely need a another PCM. Does anyone know where I can get another in Sydney Australia and have it programmed to my car?. How much would I be looking at?
Old 08-19-2011 | 12:22 PM
Hc2003's Avatar
Hi ajhoward,
I have exactly same codes on my 2003 Grand Voyager. Have you found any source in Australia?
Thanks,
Old 08-24-2011 | 06:07 PM
ajhoward's Avatar
Originally Posted by Hc2003
Hi ajhoward,
Thanks,
No, I didn't. What I found is that particular model was built in Europe, and the ECU was built in Austria. After speaking and emailing hundreds of people, which I got a few different answers, firstly you can purchase a new unit here in Australia for $1500 and then regardless of which way you go, it will cost about $200 to have the ECU programmed to your car. I found a place called Autotek Electronics, who sold a refurbished ECU for a reasonable price, until I saw this and several others, and quickly changed my mind. Apparently though I was told that this unit is sealed and therefore cannot be refurbished only replaced. I ended up going with a place called ATP Electronic Developments, who have just sent me a genuine unit from there dealer. Send them a email with your ECU part number, VIN number, Vehicle Make and Model and what your asking for and hopefully they can help you too. They did a genuine unit for me for $861.25, which included postage and a refundable surcharge of $195.37 on return of my old unit. They were very pleasant and helpful to deal with. Sorry I took so long to reply, was waiting until they sent me the unit before I made any suggestions. Having said that, I haven't received the unit yet, just sent today.
Old 08-25-2011 | 10:35 PM
Hc2003's Avatar
Hi,
Thanks for the reply. It is good to hear that you have sourced a reasonably priced one. The dealer here quoted me $3.5K. It is insane.
I've called several sources in US but haven't found one to send the unit here. I was planing to send my unit to US to get repaired but I will follow your route hopefully if it works for you.
Please let me know when you received the unit.
Old 08-26-2011 | 01:43 AM
ajhoward's Avatar
Hi,
Yep, I will. Don't even bother with the US, they can't help. All right hand drive types have the ECU built in Austria.
Old 09-06-2011 | 11:44 PM
Hc2003's Avatar
Hi ajhoward,
Any update?
Cheers,
Old 09-06-2011 | 11:52 PM
ajhoward's Avatar
Hi ajhoward,
Any update?
Cheers,
Yeah, sorry. I received the ECU, it's a re-manufactured ECU from a Chrysler dealer in the UK called "mopar". I have it booked in to be changed and programmed this Friday. Was waiting until I had it changed and was able to test it before I let you know that it was ll good.
Old 09-09-2011 | 02:37 AM
ajhoward's Avatar
Changed over. Working fine, no fault codes (except p1684, which just means the battery has been disconnected), no engine light and running fine.
Old 09-27-2011 | 02:25 AM
ajhoward's Avatar
Hi Hc2003
How did you go?
Old 09-27-2011 | 07:58 PM
Hc2003's Avatar
Hi ajhoward,
Thank you very much for letting me know.
I missed the previous message. It is good to hear that you've got ECM fixed.
I'm very busy at work and with kids. I didn't have any chance to think about it.
How much did the service charge you to fit the part and reprogram?
thanks,
HC
