2001 Chrysler T&C Limited speedometer stopped working
Old 11-14-2006 | 12:02 AM
Bigripper1's Avatar
Default 2001 Chrysler T&C Limited speedometer stopped working
"I have a 2001 Chrysler T&C Limited that has 70,000 miles on it. I
replaced the battery in it over the weekend and my wife says the
speedometer doesn't work now. I checked it out and noticed that the gauge needle
is in the 7 o'clock position which is different from where its normally
at. When I turn the ignition to the on position the needle jumps to
around the 8 o'clock position but does not move above that when driving.
The odometer still registers but there is no speed registering. What can
I do to check this out? "
Old 11-14-2006 | 12:29 AM
LostMyLicense's Avatar
Default RE: 2001 Chrysler T&C Limited speedometer stopped working
Any symptoms of the other guages...fuel, rpm? I'd start with first checking the instrument panel fuses. If you find nothing wrong I would just have it taken in and looked at. Could be something small and stupid or it could be the instrument panel needing replacement.
Old 12-07-2006 | 02:19 AM
kevinc's Avatar
simple fix possibly, on a similar post it states you can run a diagnostic check on your instruments by pressing and holding the trip odometer reset until the needles stop moving, give it a try.
Old 09-10-2007 | 09:51 PM
tdcobb7's Avatar
Have you found any solutions? I did the same thing today. I disconnected my battery to clean the terminals and my turn signals, speedometer and tach are doing the same thing. Please help.
Thanks,
David
Old 12-03-2007 | 09:44 PM
VoxDrive's Avatar
I had the same problem with the speedo, and the reset as posted WORKED beautifully. Thanks!
Old 12-04-2007 | 01:55 PM
moe's Avatar
moe
disconnect battery ,wait 3 mins ,and before you reconnect battery turn key in the on position.now connect battery.let me know,moe.
travisp33
06-08-2021 11:46 PM
deerhunter
10-26-2015 02:47 PM
michaelcerruto
04-11-2008 01:56 PM
mfalcon
02-08-2007 02:03 AM
brad
11-21-2006 07:40 PM
