2002 crd o/s c.v joint
Old 02-24-2011 | 03:09 PM
voyager_dan's Avatar
Default 2002 crd o/s c.v joint
hi all ,having loads of grief trying to change the o/s c.v joint i needed to do the bearing on the same side so thought i would do both together
but no matter how hard i beat the joint it would not come off
has anyone else had problems with this??
i did one on my last voyager (1998 2.5td) and was no problem at all
dan
Old 02-24-2011 | 07:44 PM
Djinn-n-Tonic's Avatar
Did you release the circlip?????
There are two types..one is just a ring, which will center itself and slide out on impact...the other requires a pair of snap ring pliers to expand it while iy is being "Knocked-Off"....
Ifr you look carefully at the joint, wipe the grease out of your way, and look for the two protruding "EARS" on the face of the joint where the shaft meets...Once you see them it will make sense......Spread them apart to release.
Old 02-26-2011 | 01:34 PM
hi yeah did look for this but it is the ring type which is supposed to close on impact but it isnt for some reason,the new joint has a new clip with it
will attack this another day may have to cut through the joint
Mcex
09-24-2014 12:44 PM
chryslervan
03-02-2011 12:28 AM
bjkroll
03-09-2010 09:41 AM
tk1780
05-21-2008 09:05 AM
jakefree
01-27-2007 08:36 AM
