2002 town and country limited
I own this for 2 years, is been always service on time,
we have over 100k miles and now there is a small vibrations when you turn left or right if the vehicle is park
when the vehicle is driving or moving there is no vibration,only when park orturning very slow
the funny thing is today i got a used town and country limited with 60k milles
and same problem same vibration,
any ideas what is wrong with this vehicles ?
thank you
thank you
My 2002 ltd does the same thing. I read somewhere it could be the screen filter in the reservoir tank and/or the return hose is clogged, restricted or collapsed. as of 1-16-11 I have not done anything to it, I'll try the screen first.
Chrysler has released several bulletins on this issue, varying in years and models, all the way up to current.
Google "Steering HONK".......
Apparently all of the fixes involve Making fluid capacity larger, either by adding a bigger cooler, longer hoses or a larger Reservoir......
The cheap easy fix.......Overfill the reservoir by 3/8 ths of an inch......
Now....Before you go bashing it,.....Consider this as a trick used by a "Flat Rate " Chrysler tech.....
3 Years later maybe I can help, I remove all the oil it was black dirty and
install a small $30.00 cooler under the van use new oil and problem solve.
Before I did this, I replace the pump and was a big waste of time and money
