2003 T & C power steering whine
I have a 2003 T & C Limited with all-wheel drive. It has 60K miles. A little while after buying it the power steering started whining. It sounds like it is low on fluid but it is full. Occaisionally it is hard to turn but mosy of the time it works well. Any ideas?
RE: 2003 T & C power steering whine
from what you described, it looks like PS pump is about to die.
for some reason, pump is not working well and that's when you hear wining. problem is, the steering rack doesn't like that either. if you turn the steering and the pump is not providing enough oil, there is too much pressure on the rack.
take it to the dealer for check up.
if there is too much freeplay on the pump or it looses oil or it makes sound when spinning, you need a new one. ASAP, to preserve the rack.
06T&Cminivan Dad
05-17-2012 09:58 AM
