2003 T&C, Speedo not accurate!
Old 01-27-2013 | 08:35 AM
nu2chrysler2003's Avatar
Default 2003 T&C, Speedo not accurate!
2003 T&C, 3.8, 4-speed auto, with correct tire size
My speedometer displays approximately 5 mph slower than actual speed. I have checked this with gps during several trips totaling 2000 miles(+/-). This is also effecting the odometer. Every 200 miles the van travels it displays 188 (+/-).
I searched this site to find other speedo problems but none like mine. The other's seem to be worse than mine. Like not working at all or jumping around. Advice for these problems focused around the "Automatic Trans. Speed Sensor Input & Output".
Would replacing the ATS Input & Output sensors correct my issue or should I repair/replace something else?
Thanks for your time!
Old 01-27-2013 | 03:12 PM
Raptor 07's Avatar
Many moons ago I had a VW that indicated 5 mph low. Dealer showed me an official looking document (not VW Corp) that stated it can read up to 7 mph low without having to repair it. They didn't. I lived with it.
- 3rd generation vans had a cluster self test you could do to verify all the gauge indications were within spec. Not sure how to do it on your 4th generation van.
- Might have the transmission pinion factor checked
- If you change anything it would be the output speed sensor. That is the "sender" for the speedo. Anything beyond that turns into big bucks.
Old 01-28-2013 | 06:14 PM
Thanks again Raptor
Merlecollins
02-03-2014 06:24 AM
JR13
01-27-2011 10:35 AM
praasch
07-24-2009 12:01 PM
roadbandit
05-04-2009 05:12 AM
mark44004
05-22-2008 08:31 PM
